I decided, with 120 or less compression in my new (to me) Camry's engine which has 275k miles, I may be better off rebuilding it instead of just replacing the head gaskets.
After rebuilding a few 3-AC engines I have a general idea of what parts to get, but the engine in the Camry is much more complicated, so I want to make sure I don't miss anything. (I'm thinking I'm probably missing sensors I might need to replace, for example).
So here's what I have between my ebay and rockauto carts:
head bolts
oil pump
felpro full gasket set
pistons/rings/bearings
alt/AC belt
PS belt
timing belt kit (water pump, belt, idler, tensioner)
hydraulic timing adjuster
auto trans filter
spark plugs / wires / distributor cap / rotor
fuel filter
air filter
toyota thermostat
Will probably get a Toyota head gasket unless the fel pro ones look okay.
Am I missing anything glaring?
head bolts
oil pump
alt/AC belt
PS belt
auto trans filter
fuel filter
air filter
toyota thermostat
