1992 Pickup A/C conversion from R12 to 134a
1 reading
39K views 13 replies 9 participants last post by  TOYR
i have a 1992 toyota pickup and the a/c has been out for about 8 years. i am finally going to try and get it working again and convert it to 134a. when the a/c went out it had a leak somewhere but everything was working at that time. now i have no idea what is still working and what is bad so i don't know what i need to replace but at the very least i know i will replace the dryer and add 134a compatible oil. can anyone tell me if there is anything i should replace while i am doing this conversion and what all is involved with this conversion? thanks for any help!
One of the under hood stickers tells you what the A/C system uses.
I can't remember the change over year.
The leak has to be located and fixed, then a vacuum pulled on the system to get all the crap and and to verify no leaks.
Then add R134 and some PAG oil.
Yo have to change the HI/LOW side fittings as noted above.
If unsure if it's been converted, look at the fittings. R12 uses small screw-on fittings. R134 looks like a short fat mutated air compresser quick disconnect.
You'll probably have to change the compresser. Sitting for 8 years, exposed to atmospheric moisture and oxygen, nothing to circulate lube. moisture reacting with residual refrigerant to make flouric acid (IIRC...one of the nastier ones anyway)
If you want to be cheap though (and risk wasting the first refrigerant charge) just replace the R/D, pull a vacuum, then fill it up and see if it works.
i found the leak, it was the valve on the high side. i just replaced the valve stem on both the high side and low side valves, put about 2.5 cans of R134a in there and it's working great and blowing cold! i didn't change or replace anything else. a/c hasn't been used in 8 years but everything was still functioning.
#11 ·
Now we start betting on how long it works :clap:
You use a vacuum pump meant for AC work. If you don't vacuum the air and moisture out before putting refrigerant in, the nitrogen won't do much but reduce efficiency. the moisture, oxygen, and refrigerant will react to make a very strong acid (hydroflouric?) which will usually kill the compresser first then everything else.
#12 · (Edited)
i appreciate the words of encouragement. :clap:
i guess we shall see and i will keep everyone updated. that being said, if it does go out again and i have to replace parts that are over 20 years old it doesn't seem like i'm losing anything. if my a/c gets me through the summer i'm happy and i can replace everything over the winter at my leisure, i needed a/c now and i got it and i didn't have to spend any money, i'd say that's a win.
