I’m absolutely stumpped. 2001 Camry 4 cylinder only 94k original miles here. I had this slight rattle noise start about a week ago when car was around 2k RPM and it would go away over that. it sounded like timing belt was needing to be replaced like belt was slapping against timing cover or maybe weak water pump. Had my mechanic do the timing belt water pump kit with tensioners and pulley and new serpentine belt and power steering belt. But after him doing the job 3 times trying to find the noise he came to the conclusion it could be the cam bearing behind the cam sprocket. I’m not sure what to think at this point and don’t wanna have him order a bunch of parts and play trial and error at my expense. Figure I upload here see if anyone may have heard this before or could help with any suggestions. The alternator is fine and not noisy since it was still there after he started the car without accessories attached so that’s been ruled out. Any suggestions would be greatly appreciated! Thank you!
https://youtu.be/pZ4dDwAheEY
