Hello,
I have noticed that my Camry has started to use up a little oil. The car currently has 208K miles on it and it uses about a quart of oil every 4-5K miles. I run Mobil 1 Synthetic and do my oil changes every 7-8K miles. I decided to perform a compression test to see how worn my engine is. The problem that I am having is that I do not know what is normal for this car. My readings are between 185-195 psi but doing the math for the compression rating of the motor I come up with a normal compression of 141psi. Can someone tell me what numbers I should be getting? Thank you.
