2002 Corolla 5 speed high RPM @ Highway speed
1 reading
14K views 15 replies 9 participants last post by  mrfoxboy
Hello everyone, I am new here (new car to me) and have a question
I have an 2002 Corolla CE 5 speed 127,xxx in which the RPMs seem too high sometimes, but only at faster speeds in 5th gear, otherwise everything is perfect
~2100 @ 55 mph
~2200 @ 60 mph
~2700 @ 65 mph
~2758-2800 @ 70 mph
This seems way too high for my liking, what is normal?
And the engine is well warmed up and I am certain I was in 5th gear, any ideas? I would really like to be able to go faster than 60 mph (thats as fast as I took it with such high RPMs). I am used to driving a diesel car and large V8 gas engines so maybe that is normal?
THanks for the replies everyone
I am not quite sure what you guys are saying between the 4th and 5th gear, should I go 50 mph in 4th and 5th and see which has lower RPM?
About the linear increase, it seems like a standard increase in engine speed, my numbers might be slightly off and the car runs smooth as could be I am just worried about running the car at 2800 RPM for a few hours at a time on the highway...
2800 RPM seems too fast to spin the engine at for multiple hours, am I just a worrywart or is that too fast for 65-70 mph?
Thanks again all!
#9 ·
Thanks again all!
Don't worry about it - 3000 RPM is nothing to this engine. The power curve actually has a sweet spot at around 3500-6000 RPMs. Max torque is at 4400 RPMs, max HP generated at 5600 RPMs.
That said - assuming that you are in 5th gear with OEM transaxle, tires are the OEM size (185/65-14).
Your engine speed should be as follows:
2086RPM @ 55MPH
2275RPM @ 60MPH
2465RPM @ 65MPH
2655RPM @ 70MPH
There might be a slight variances due to gauge resolution, but looks like most of your numbers are within the ballpark.
Running the 1ZZ-FE engine at 2500-3000 RPMs is like idling a small block Chevy. No stress at all on this car/engine - like you said, you're just used to lower RPMs.
When I tow a smaller trailer on long grades - I routinely hit 4000+ RPMs for hours. No issues at all, over the 200K+ miles that I've driven my Corolla.
Just make sure you wind out out the engine a bit when shifting, since its sounds like you are used to shifting at lower RPMs, as that low RPM lugging can be harder on these higher revving engines than bouncing off the redline.
Don't worry about it, lol for the people like me with the 3 speed auto 75 mph is 3500 RPM. so it's hard to cruise any higher than that when you have to hear the motor turnin that fast. I usually travel the interstate between 60 and 65 mph in the right lane of course haha.
I think mine revs at about 3000 at 80. Here in Colorado, many sections of Interstate highway are at 75MPH, and I usually do 5 over. I wouldn't worry about it, 4 cylinders like to rev. Heck, my Mom's V6 Avalon likes to rev. FWIW, I used to drive an 86 El Camino with a 3 speed transmission. At 80 it was at 2900RPM and I would drive like that for hours and it never hurt anything. Gas mileage wasn't any better doing 65 either.
