My A/C stopped blowing cold so I took it to Christian Brothers Automotive and they did an inspection and couldn't find anything obvious so they recharged the system with dye included in the refrigerant. Fortunately, the A/C was blowing as cold as it gets, but that all soon ended after about two weeks. So there is a pretty substantial leak. I bought a UV flashlight and did a thorough inspection of all the connection points within the engine bay but found no dye anywhere.
My thoughts were that it must be a leak since it was blowing cold for two weeks before reverting back to blowing warm air. I checked both attachment points at the condenser and the compressor and all the inline connection points where the lines/hoses hook up together with the use of o-rings as sealers, but still found no dye. I also climbed under the dash to see if anything was visible from under there, as well as opened up the glove compartment and looked behind there for any obvious signs of a leak by the evaporator. Unfortunately, I have yet to find any dye showing anywhere.
I am at a loss of ideas of what to do, because I don't want to pay an arm and a leg for a diagnosis, and I don't want to rip the dash board out to get a better look at the evaporator and find out it is fine.
If anyone has any experience/input/ideas please share. Thank you for taking the time to read my rambling story of a post. My plan is once I find the leak, is to R/R the needed part and recharge the system myself.
