2006 highlander new to me 190k miles transmission slip
9.4K views 13 replies 6 participants last post by  9009RPM
Hey guys, new to the forum, been lurking for a little bit now, figured it was time to make a post.
I picked up a 2006 4wd Highlander about 2 months ago. It is in great shape and has been well taken care of minus some major maintenance needs. At 195k, this vehicle had never had the TB replaced. First thing I did was take it to my shop and they did a once over, replaced timing belt, water pump, tensioner, checked plugs and said they were ok. Fluids were all checked out as ok including transmission.
I know for a fact this has never had a transmission service. In face the shop that worked on this prior to my ownership has told me that these transmissions are sealed unites and cannot be flushed or changed. I immediately took that shop off of my list as any potential service provider.
so, I'm noticing, and i've read here that others are noticing, this transmission almost gets confused from 2nd to 3rd gear. It's as though it tries to shift, then changes it's mind. If i don't accelerate hard, the transmission shifts just fine, but if i'm accelerating past 3k rpm it does have a pretty bad slip or jerk when trying to change from 2nd to 3rd gear. Is this something that can be fixed with a transmission oil change, filter change, etc? Also, is it terrible that this unit has not been changed at all and it's got 200k miles now. I can say the rest of the car seems very solid, the transmission does not do anything out of the ordinary except for this wierd slippage I have described. I also noticed whoever has changed the oil in the past for this vehicle has taken it upon themselves to cut a flap in the plastic skid plate in order to access the oil filter. Personally, i pull the skid plate off as i get much better access....
Thanks in advance for any pointers and suggestions on the tranny issue. Hopefully a simple fluid change will get rid of this slip, what do you guys think?
A tad impatient for free advice, eh?
I'd do two drain and fills (~3.5 quarts, each) or detach a trans cooler line and do a complete trans fluid replacement. See other threads and stickies for tips on that.
If the '06 specifies Type-IV fluid--I forget which year Toy switched to WS-- in my opinion you can safely use Valvoline MaxLife synthetic. I used it in my '02.
If WS fluid, I'd use real WS. Valvoline MaxLife synthetic is supposedly a good substitute for WS.
Drive it for 100 miles. If it stops acting up, then enjoy. If it still acts up, add Lubeguard Red per bottle instructions.
If you're really motivated and the above didn't fix the problem, then drop the trans pan and clean the screen and/or change the filter--again don't know if the 5-speed uses a filter. Unless you are very good with say clock making, I'd avoid taking the valve body apart. Many valve bodies are angry Jack in the Boxes waiting to eject all manner of springs and check balls to nether places.
If it still acts up, then drive it until unbearable or until it conks. Consult a professional or AAMCO if you're in the mood to be pillaged.
Reactions: ricco750
I did a quick check at RockAuto--apparently the '06 does have a filter, although the surface area is quite large and for Toy transmissions, probably a lifetime part. A clogged filter would not be my first guess re: your symptoms, but the filter is cheap and it sounds like you got time to kill. so replace it with your first drain and fill.
And a caveat; while fluid in VERY bad condition seems to cause all sorts of shift issues and is a relatively cheap "can't hurt to try it" thing to replace, there are many other mechanical bits that fatigue with age and miles; solenoids, clutch seals, friction materials, pump condition...things a fluid change or elixirs may not remediate.
Lubeguard seems to alleviate minor solenoid stickiness, mild clutch chatter and the like. It certainly helped my '02 in that regard.
Well I changed the fluid today put 3.7 qts of max life in. Immediately I notice the trans lost the slip and shifts great. The old fluid looked like motor oil coming out so it was bad. I had a filter on hand but for the life of me cannot get a wrench on one of the booger bolts atop the frame. Any way to do this? I really want to change the filter. By looking at this fluid I can imagine the filter is full of badness. I've heard some say to loosen motor mount and Jack up trans? I tried several wrenches a knuckle adapter and anything else I cold find and cannot get a turn on one of the bolts. Luckily I knew they were hard and started on those first. Gave it about an hour of fiddling then put the plug back in and filled with fresh oil. Any pointers would be great!
#13 ·
I removed the bolt from the "dog bone" mount up top, and removed the bolt from the front lower mount beneath the oil filter (had to use a breaker bar to loosen this bolt). Then I used my jack with a 6X6 block of wood under the oil pan to lift the engine a little over an inch. That allowed me to get a wrench on those tranny pan bolts.
#14 ·
While you guys have the engine lifted a little bit, it's the best time to replace your lower control arm if they are old or bad. Why did they have to bury that bolt right under the engine mount.
