I'm having trouble with my 2007 corolla fan switching on when the car reaches temp, although the cars fan works with the a/c on and only with the a/c on . I changed the temp switch that sends power to turn on the cooling fan(also did the relays and check fuses all are good), I also tested the coolant temp switch fail safe by unplugging the sensor with the key in the on position the fan is supposed to come on full speed, but it does not come on at all.
