I have a 2008 Highlander Sport and over the last year or so I've had some intermittant issues with the power locks not working properly with my remote. It started with the Driver's door not locking but all other doors would. Then it would be the Driver's side rear door not locking and I would have to do it manually. I had always assumed I had did something with the key fob that screwed it up because it seemed to be "corrected" if I played with the buttons on the remote by pushing and holding some of the buttons and it would randomly be "fixed".
Now, it just seems to be the Driver's side rear door not locking. I have also tried to use the main putton on the driver's door and also using the key to lock the doors but it still won't lock. I noticied that I also don't get the "beep" confirmation that the doors were locked with the remote that I normally got. I have also tried to use another remote with no luck.
I noticed today as I got to work that after I manually locked that door and then hit the button on the remote to lock all of the other doors that I actually got the "beep" this time. I was in a hurry so unable to confirm if it is working again or if maybe the "beep" only happens when all of the doors are actually locked or what. (anyone else know if this is the case?)
I have tried to search here and elsewhere on the internet and haven't had much luck. I have seen some other Toyotas having some issue with actuators but nothing that would explain why it seemed to bounce back and forth between both doors on the driver's side before.
The only thing I can think of to try would be to see if the passenger side lock button works for it, but I'm at a loss other than actuator(s) on the fritz.
Anyone else have any ideas??? Thanks for the assistance!!!
