2010 Camry 2.5L I4 - Leak from sensor?
2.1K views 12 replies 4 participants last post by  kenny326
Hi,
Have been looking @ my 2010 2.5L I4 and there seems to be a gradual leak around this sensor just below the valve cover.
Anyone know what sensor this is,
and how to fix the leak?
Remember that if you pull that sensor, you will likely have coolant come out (assuming it's a coolant sensor). Sometimes it's a lot of coolant.
Unless you can verify a leak, I'd leave it.
If it is leaking, plumbers tape works fine.
#11 ·
Black dirt started piling up around that sensor every month. All other areas looked clean (I cleaned up the engine before).
I just cleaned up that area again. Will start observing every week or so.
If dirt starts getting collected right around that area that means there's something leaking out. I'll use teflon tape then.
