I'm having intermittent starting issues on my 2012 Camry SE I4 with 93k miles. Sometimes the car will start perfectly fine and sometimes will crank a while to finally start up. I changed spark plugs thinking that might solve the issue but still having it. I had no issues starting up this morning before going to work about 56 degrees outside. I read that some people have issues starting when the car is warmer, I will have to test it out moving forward. I replaced my battery about 2 years ago and the voltage is reading about 12.3 volts. No corrosion on battery terminal. Air filters have been replaced as well. Could it be the starter going bad? Any ideas?
