2019 corolla le 225k miles car will not drive or reverse
4.6K views 10 replies 5 participants last post by  MRussel
Hello,
2019 corolla le 225k miles.
car will not drive or reverse. i got check engine light solid and three codes.
P075B Shift Solenoid G Performance / Stuck Off
P2829 Pressure Control Solenoid K Performance Or Stuck Off
P0841 transmission Fluid Pressure Sensor/Switch “A” Circuit Range/Performance
please help..
Unfortunately the transmission does generate debris as I found out when doing a fluid and filter change on my daughters car at 110K miles. At double those miles and perhaps double the debris, looks like the magnets and filter/screen could not keep that debris out of the hydraulic computer, which is where I suspect those solenoids are located.
If it is debris related... no other causes, then...
I think at a minimum you will need to do this...
But you will need to go a bit further and take off the valve block and clean out all the circuits / solenoids (there is wiring in there). Refill, start it and see if it runs and drives.
If it does run, then do a couple of drain and fills (leaving the sump on) after about 1K miles.
Then plan on another drain and filter in say 60K miles.
If you are not up for this as a DIY project and your dealer won't do it, you will need to find someone who will.
CorollaAtl- Check your VIN for recall.
Recall 18V901000 Solution
Toyota has notified owners, and dealers will replace the CVT and torque converter, free of charge. The recall began April 22, 2019. Owners may contact Toyota customer service at 1-888-270-9371. Toyota's number for this recall is J17/J07.
