2022 Corolla Hatch - Engine Cover
19K views 52 replies 20 participants last post by  carpionorman06161966
As I'm sure you've noticed, our cars lack any kind of engine cover. By no means is this an issue, but I prefer the cleaner look of having one. No USA sold vehicle with the M20 comes with one, so I started digging to find a solution.
It appears the Chinese market Wildlander (RAV4) comes with the M20 and has an engine cover. Could locate some part numbers but could not find a way to source one. There may be other regions and models where you could source from, but as of my findings a few months ago it's impossible.
I noticed the cover clip locations are apparently identical to that of the Camry/RAV4 with the A25 motor and picked up a used takeoff cover. It's too tall to clear the windshield cowl and sadly does not fit.
However in digging through Aliexpress I came across this option.
It's listed for the Corolla Cross, but given that they use the same M20 engine I figured it'd likely work. It does! 2 things to note though, one is that it pushes up against the air shroud at the back of the engine but doesn't seem to be harmful in any way, the other is that at the front passenger side edge it rubs against the hood insulator pad. Heat gun and some persuasion could be used to curl that edge down a bit for extra clearance, but it doesn't seem to be an issue.
It came well packaged in a decent sized box, and includes 2 ball studs plus a rubber grommet for installation.
One stud screws into the pre-threaded location here. The other goes on the back of the cover itself.
Next up the rubber grommet slots into this existing location.
After that the cover snaps on to the 3 mounting points on the valve cover + the 2 additional ones added.
Access to the oil fill and dipstick are unaffected. There's a variety of color options available, I chose the black and silver as it was the most OEM looking. The cover itself is high quality feeling plastic, with foil backed insulation on the underside for thermal and sound insulation. The silver portion is painted and not perfectly sharp on the edges but for the price I cannot complain. The Toyota logo looks genuine and is nicely chromed.
Overall very pleased with the result! It tidies up the engine bay, hiding some of the rats nest of wires and hoses. Everyone that I've shown says it looks like an OEM part and is shocked that it's a Chinese knockoff special. For $70 it's way nicer than I ever expected and fits so well.
Nice find. I've been looking for one of these. I know the Lexus OEM one fits, but I didn't want the Lexus logo and they're sometimes hard to locate at a decent price:
Anyone tried installing this or any engine covers with FSTB installed? I have a Megan Racing one and it goes right above engine oil fill cap...
Have to applaud @andrew_l_s for his effort to share all the info with the community. Good job.
I am old school, or just old. Engine cover was not a thing for a lot of the cars I owned over the years, until recent years. It does make things look cleaner and more upscale under the hood. Since I am so use to not having them, I actually prefer no engine covers. One simple reason is that I can do a quick visual check for leaks or other potential issues when things are wide open. The extra step of taking off the cover would prevent the lazy me from doing most of the checks.
#12 · (Edited)
I can agree with you on NOT having a cover (I'm old too). But...that was when engines were nice to look at and didn't have all the hoses and wires all over the place and you wanted to show them off (I'm thinking my '69 Firebird). However, these engine are not visually pleasing to look at, so if I can cover it to at least look a bit better, I'll cover it up. My Zed has a pretty motor even with the covers
:cool:
#16 · (Edited)
#23 ·
Всем привет. По этому вопросу думаю установить мягкий декоративный чехол от Toyota Camry 75 с таким же двигателем как у нас, но не уверен, что он войдет в подкапотное пространство и не заденет его. Однако сам чехол от Camry 75 очень хорошо гасит звуки, которые любят издавать наши шумные двигатели.
#39 · (Edited)
Всем привет. Подтверждаю, что декоративный кожух двигателя никак не влияет на теплоотдачу двигателя в атмосферу. Более того, на всех автомобилях с двигателем M20A-FKS (Camry, RAV4), кроме COROLLA, установлен декоративный кожух двигателя, в том числе и для снижения шума двигателя. Нам его не дали чисто из соображений экономии.
#40 · (Edited)
Всем привет. Подтверждаю, что декоративный кожух двигателя никак не влияет на теплоотдачу двигателя в атмосферу. Более того, на всех автомобилях с двигателем M20A-FKS (Camry, RAV4), кроме COROLLA, установлен декоративный кожух двигателя, в том числе и для снижения шума двигателя. Нам его не дали чисто из соображений экономии. View attachment 462937
That cover is for the 2.5 A25A-FKS engine... Here is Toyota's M20A-FKS engine cover:
M20A-FKS 2.0 Engine Cover - 12601-24011
Cylinder head for Toyota RAV4 MXAA52 - Genuine parts - Amayama
Buy Genuine Toyota 1260124011 (12601-24011) Cover Sub-Assy, Engine, No.1. Prices, fast shipping - Amayama
