2022 Corolla's battery dies after idling
4.8K views 32 replies 12 participants last post by  invader
Hi all,
A month ago I left my car idling without the engine on, only the battery, for about an hour. The battery died (no engine start, clicking sound) so I called AAA to come change it, but they plugged a thing into my battery and alternator and said they were both fine. I tried to start the car again and it turned on. It's been working fine ever since
I thought it was a one-off thing, so I put it on idle again today, no engine only battery, for about an hour. The battery died again while idling (no engine start, clicking sound). Not sure whether to call AAA again.
Anyone have any idea what this problem is?
Idling would imply engine running. So if engine is not running, then it is on accessory mode? Were any electronics on in the car, e.g. radio head unit? If yes, to me this seems normal for 12V battery to fully discharge after an hour of accessory with radio, etc. on. After 2 full discharges of the 12V battery, it will likely sulphate and you will need a new one, if not immediately, then soon...
On a related note ,I find it very annoying you can't bypass the auto shut off in accessory
There's far too many idiot safeguards anymore
And yes I've tried parking in neutral, which does work on my mazda3
It would take 6 hours listening to radio to kill a battery
I can watch the voltage on my r8 ,when Toyota decides it's too long ,it's still 12.1 volts
I don't think it's a v reading at all ,it's just a random amount of time they chose
And I'm stuck with
Cuz insurance and aaa crying
#17 ·
I'm still unsure about AGM for my Corolla. I know very little about them and have read that some cars are lacking the "charging protocol" for AGM. But, then again, there are quite a few people who have installed them in Toyotas.
I still have a few months to make a decision and will do further research.
#19 ·
You should monitor what voltage your alternator provides. AGM seem to charge at lower voltage.
AGMs require over 14V from the alternator to charge sufficiently and give a 3 to 5 year minimum battery life. There are different Denso alternators in Toyotas and also the ECM programming that controls the alternator is different in various years and models. On many recent Toyotas (especially with auto start/stop function) the Denso alternator will provide a continuous 14.2 V which is OK for an AGM. On some earlier years and models (Tacoma, Sienna) the alternators only provided a maximum output of 13.65V and the charging rate varied and floated with RPMs, temperature and accessory load. Battery replacement in recent Toyotas requires NO "registration" or changes in any Techstream battery related settings...unless you replace an OEM EFB with a traditional, old fashioned flooded lead/acid. Then you do need to change the "dedicated" battery setting to "other."
#24 ·
You nailed it. I've always had extremely good luck with Walmart batteries and in my experience their warranty procedure, should anything go wrong, is stupid simple.
The $20 difference between the two you posted would seem to make it a no-brainer to go with AGM.
#31 ·
yeah that's my 2022 6MT HB, I'm jealous of your LN2 it just seems to make more sense!
I find it strange the HB changed to LN1 at some point, I think in 2022 actually but could have been sooner
Looks like the smaller LN1/H4/140R battery tray came out in 2022. My 2019 6MT HB has the larger LN2/H5/47 battery tray.
2019-2021 H5 Battery Tray - Toyota part # 7440412560
2019 Toyota Corolla SE Hatchback 2.0L M/T Battery Tray - 7440412560 | Toyota Parts Direct, London ON
USA built H5 Battery Tray - Toyota part # 7440412580
7440402580 - Toyota Battery Tray | Toyota Parts Direct, London ON
2022-2024 H4 Battery Tray - Toyota part # 7440412600
2022 Toyota Corolla S Hatchback 2.0L M/T Battery Tray. JAPAN BUILT, 2023, 2.0 liter - 7440412600 | Toyota Parts Direct, London ON
So battery is installed, it is almost plug and play.
The bottom right bolt has a small gap to fully seat, so I stacked 4 washers then bolted it down...
You'll want to remove the air intake box to do this, trust me. It's simple though couple plugs and 2 screws.
There is a very small difference in the alignment of the right side screws, a couple MM, since the plastic is flexible I just started the screws then went back and forth tightening them.
Trying to tie down the middle hole was not practical, however after tightening the others I was able to rock the car using only the battery tray so I'm satisfied. Very small amount of movement in the top left corner but not worried about it.
The bottom right bracket I had to take off my old tray since it wasn't included, it was slightly off but I just tightened it down and it holds the battery well
Here it is all installed and working well! Nice upgrade from the older Corolla version to the newer one :D:rolleyes:
