Hello all, new to the Forum. Recently purchased a 9th Gen 2025 Camry XSE. had the car 20 days, put 600 Miles on it and the panoramic roof has completely failed in the open position with the right side of the glass being sucked down into the track upon opening and hitting the front glass of the rear panel. Front panel is miss-aligned, jammed and stuck. LH aft corner is extremely high and RH aft corner is touching back panel The open and retract button is inop and the window shade button has a loud plastic gear clicking noise when pressed to operated. Does not move shade at all. cable is skipping the gears on the motor. From my research i have found that these are a giant maintenance task and a majority if not all of the internals in the cabin/headliner need to come out to even access. From what it sounds like is a misaligned or broken motor/ cable set. major internal failure. The Dealership has had the car since may 30th and have thrown in the towel to now reach out to Toyota for guidance. all covered under warranty, however brand new car 600 miles and if everything has to come out just to get access to the roof, would you keep it or right it off after it is fixed. Lemon law may apply also if they can not fix within timeline. Very unfortunate and beyond frustrated. Thoughts. I know there have been issues with the earlier Gens as well, but curious about the 9th gens and if anyone has had any issues? Thanks.
