just saw a tacoma commercial and it said the new taco gets 26 mpg on the freeway,it looked like a 4x4 too, this cant be right can it?
maby they were talking about the 4cyl.....HILLCLIMBER said:just saw a tacoma commercial and it said the new taco gets 26 mpg on the freeway,it looked like a 4x4 too, this cant be right can it?
No lift, but I have dual exaust, and 32" mud terrain tires, but that should not be costing me 5mpg, right?tone9 said:ummm....wow...I have a 05 2wd prerunner....I get 15????
I'm sure the commericla is for a regular cab 2wd. The prerunner has the bigger tires/suspension and would get very similar ro a 4wd...tone9 said:ummm....wow...I have a 05 2wd prerunner....I get 15????
Sorry, Genius - I'm too much of an idiot to figure out what provoked that response.NorCalTacoma said:
I don't know. You say you get 15 on hwy, or average for your driving?tone9 said:I wonder why everyone else with the exact truck as mine gets atleast 4-5 MPG more? Its not like im hauling a load, or drive like nascar :ugh3: this is upsetting.
Definetly logical, and makes perfect sense...I will have to fill up and test it out...I do though, however tend to drive about 80 MPH on the highway...Ill try driving like an old lady on a tank, and see what it gets me :ugh3:msibille said:I don't know. You say you get 15 on hwy, or average for your driving?
I get 16/17 in town, 22/23 on hiway in my 05 DC.
Perhaps you accelerate too softly?
I/C engines are mechanically more efficient with large throttle openings.
(The throttle is a restriction on the air flow, the engine works as a compressor before burning fuel to expand and extract energy. The throttle is a restriction to pulling air in and the work to do move the air volume over that resistance is parasitic to the engine output. (Before I get jumped by the intuitives, obviously running with a larger throttle setting than needed to maintain speed will accelerate the vehicle, higher speeds of the engine and drivetrain increase energy lost to friction, and higher vehicle speeds increase aerodynamic drag forces in proportion to the square of the velocity. That's why the fuel use goes down in overdrive and why higher highway speeds burn more fuel. You also gain if you gear to operate the engine at the peak of it's efficiency curve.)
In any event, moderate acceleration will get you up to speed with the engine at a better efficiency (though flooring it is usually not the most efficient). Slowly accelerating doesn't take advantage of the higher efficiency of the engine at larger throttle openings to get the work done of accelerating the vehicle.
Just a thought.
OTOH, I would think that only really tough driving -which is not your case, or something wrong would cause you to get 15mpg highway when the rest of us get it in the low 20s. Are you driving 80-85mph highway or something? (Remember, aero drag is proportional to the square of your velocity. at 10mph, rolling resistance of tires and friction in the drivetrain are the greatest drains on energy. at 80mph, your aero drag is 64 times what it is at 10mph, and 78% HIGHER than at 60mph. Even at 65mph, your aero drag is only 2/3 of what it would be at 80mph. (of course, this is simplified, you can have different flow patterns of air and change the relationship some, so it's not a "fixed" quadratic equation in that sense, but you'll find the results are as dramatic as the above would indicate.)
Let us know. It'll be good to see what difference you get btwn the 80mph and 65mph mileage.tone9 said:Definetly logical, and makes perfect sense...I will have to fill up and test it out...I do though, however tend to drive about 80 MPH on the highway...Ill try driving like an old lady on a tank, and see what it gets me :ugh3:
Hey Tone, I drive like the old lady on a tank, I set the cruse at 65 and go.tone9 said:Definetly logical, and makes perfect sense...I will have to fill up and test it out...I do though, however tend to drive about 80 MPH on the highway...Ill try driving like an old lady on a tank, and see what it gets me :ugh3:
From my testing using a scangauge I've concluded that the slower the acceleration the better for fuel economy. I have a 10 mile commute at with some 55 mph but mostly 45 with a few stops and some hills. I did 3 days in a row with essentially equal temperatures.msibille said:Perhaps you accelerate too softly?
Just a thought.
No doubt that you're going to use fuel at a higher rpm. Also, the difference you are looking for isn't instantaneous fuel economy, but trip-cycle. Again, the point is not to run at high engine speeds, quite the opposite, but to run at large throttle openings. Higher rpms requires more pumping (you've got to fill and empty each cylinder more times per minute), so opening the throttle doesn't help if you have to run more air thru to fill the cylinders. Plus you have add'l frictional losses, and pumping losses thru the exhaust system at higher rpm. The goal is to have large throttle openings at moderate rpms -you achieve that with optimum gear selection.worthywads said:From my testing using a scangauge I've concluded that the slower the acceleration the better for fuel economy. I have a 10 mile commute at with some 55 mph but mostly 45 with a few stops and some hills. I did 3 days in a row with essentially equal temperatures.
Results
Gentle throttle 1-2-3-4-5 shifting 2500 or less 33.4 mpg.
3/4 throttle shifting at 4000 1-2-5 shifting. 28.8 mpg.
WOT shifting at 5000 1-2-5 shifting 27.8 mpg
The obvious variable was red lights I hit, and I had 6 stops during the 3/4 throttle test and therefore I had 6 accelerations.
The WOT test was even worse than the 27.8 reflects as I only had 5 stops.
The gentle throttle test was how I normally drive and I had 6 stops along the way.
I'm convinced slow acceleration is better for fuel economy.
