Got the dreaded code 52 today on the wagon, specifically "Open or short circuit in knock sensor signal (KNK)". I've been trying to find the part number for the knock sensor pigtail, anyone know what it is? I failed to find it in the diagrams.
You could try mounting a knock sensor externally like on the engine lift hook so the code goes away.apparently it will retard to 0BTDC. that explains why my 2vz feels so underpowered....
Forgot to respond to this. I wish the pigtail could be easily replaced, but the intake manifold has to be pulled. The intake gaskets are surprisingly expensive over $50 for the set.That does look like it should be the right part - though there aren't any good pictures of it online, oddly enough. Let us know how it goes. It seems odd to me that they have a separate short pigtail for the knock sensor, but I guess that allows you to take the harness off the motor without removing the intake manifold...
-Charlie
the 2VZ is a real pain to work on, worse if you have ABS then you want to shoot yourself. Imagine what a dealer would charge to replace a knock sensor. :lol:As for me, I'm glad my knock sensor is 'easy' to get at on the back of the motor, and away from the worst heat of the engine bay.
-Charlie
That's what I'm afraid of. When you have it as an intermittent that spells trouble.Some people are completely unable to fix the issue, even going so far as to replace the sensor, the pigtail, the entire engine harness, and the ECU without luck.
Not sure how the circuit actually works. Consider this, if you disconnect the knock sensor you get a code right away not when knock happens. Which tells me the computer is always sampling the sensor.A bit surprising, but it does look like Toyota went with a resonant type sensor. I wonder how knock disturbs the signal.... assuming it just increases the amplitude?
It wouldn't surprise me if Toyota put in an analog bandpass and RMS detector and fed that to a low-ish speed ADC input. Then it would just have min and max expected values for each RPM range.
-Charlie
The sensor has no conductivity it's an open circuit, if you rap it against something (do this gently) it does generate voltage.That could be the circuit missing the 'pull down' of the sensor - basically, the signal goes to full-high when it should be somewhere mid-range. There isn't much on the sensor at idle in terms of AC signal. Testing involves revving the engine to at least 2k RPM and as high as 4k RPM.
-Charlie
Intermittent failures can't be tested with an ohm meter, because well the problem is intermittent. Highly probable your knock sensor harness is bad. I would get a 1988 ECU it will probably work and didn't have the knock sensor circuit.I had previously, to start to fix the error 52, removed the upper intake, removed and inspected the original knock sensor, swapped it with an OE (see previous posts), and, while I was there, tested the knock sensor pigtail the same flexing way. That pigtal, and the wiring harness, are 100%. There is nothing wrong with them.
