So lately my car's ABS, TC, VSC, and emergency brake lights have been on with those systems not working (E brake has never worked, but the light didn't use to be on). Apparently this is a "common issue" due to the wheel speed sensor failing. Since the speed sensor is located inside the rear wheel bearing they have to replace the entire wheel bearing assembly ($400 part), plus the wiring harness ($80) in case that's the culprit. I went to an independent shop for a second opinion and they basically gave me the same story. But they also told me they "talked to a Toyota dealership" for advice on the issue.
I found the OEM bearing online for $250, but they told me they can't (or wont) install parts I purchase on my own. Also I've called customer service to see if my CPO powertrain warranty would cover it, but it wont because it's not considered a drive wheel. The indie shop said they were willing to try just replacing the harness first, but I'm not sure if it's even worth the time / money. That might just be tacking on extra labor costs for nothing.
Does anyone else have experience with this issue? Are there no other solutions? I'm horribly uneducated about stuff like this. This is the first major problem I've ever had.
