Just swapped out my 9006 lo-beams with 9005's, courtesy of Bluemeanie's handy guide in the Camry FAQ. It was a straightforward procedure, but I took my dear sweet time and it was about a 45 minute operation. I was afraid of breaking the glass on the bulb... and I was suprised to learn how easily cut down the plastic is.
Guys, I oculd plainly see the difference in broad daylight... before if you got down in front of the car and kneeled in daylight with the 9006's, you couldn't really make em out. Now you definitely can! When the sun goes down, I'll adjust the beam. I made sure to clean the bulbs throoughly with rubbing alcohol to avoid a premature death.
For the record I used Sylvania Cool Blues... they don't give up a whole lot to Silverstars and supposedly last longer. Quite a bit cheaper too
(yes that's why I got 'em
ONe note though- the FAQ says use the rubber O-ring off the 9006 and put it on the 9005 to ensure a tight fit- it's not absolutely necessary, my 05's fit snug without the second O-ring.
Steve
Steve
