Hey everyone :hi:
I have a problem with my GF's '94 Camry V6 LE that has me somewhat perplexed. I'll start at the beginning.
She bought the car in March with approximately 135k on the odo. It's a California car so it's, overall, in very good shape.
A few months down the road it started doing this strange kind of bucking when trying to accelerate hard (full throttle). However, moderate to 3/4 throttle was fine. Then it started to do the same bucking even at 3/4 and then 1/2 throttle.
I checked the plugs and saw that they were the originals. So I swapped them out with NGK plugs and it seemed as though the problem went away.
About 2 weeks later it started doing it again, but not as bad.
Fast forward about a month, my GF calls me from the shoulder of the freeway saying that the car has no power and can't go over 20MPH. Being that the car was in a precarious location I suggested she drive it to my house which was only about 1.5 miles away. When she got here the car was running really poorly and it seemed as though it was actually smoking from under the hood (not steam). The check engine light came on and it threw a P1300 code.
Google search and find out that it's Ignitor circuit malfunction bank 1.
The car sat until the next morning, it then seemed to run and drive just fine. She drove the car for a couple of days with no problems.
She then drove about 30 minutes away and still all was well. On her way back she stopped at a tire store to get a tire repaired. The car stalled out as they were pulling it in to the shop. Wouldn't start. They did some minor diag and found it had no spark on the no.6 cyl (easiest one to access). Finally after a bunch of cranking, the car started and seemed to run ok and she left.
The car died at an intersection not far from the shop; it would crank but not start. Towed it to my house.
The car alarm was acting strangely. Sometimes it would arm itself for no reason. The LED would sometimes flash, sometimes be on solidly sometimes off. Sometimes it would stop the car from cranking and so on. So I removed the alarm unit completely from her car.
While I was at it, I noticed that the battery terminals and the (+) cable were severly corroded. replaced the (+) cable and both terminals with nice painted marine units.
However, the car still has trouble starting or staying running.
Reading up on the P1300 code, it suggested that I replace the ignitor since there's no way to test it. Spent a whole day looking for a used one and finally found one off of a '94 ES300. I installed it and the car started. However, it only ran for about 30-40 seconds before it died. Then it wouldn't restart. If you keep on cranking, it'll usually restart and run for ~30 seconds, then die.
So now I'm thinking that it may be a fuel delivery problem. Removed the back seat bottom and loosened the pump so I could check for operation since I couldn't hear it. It seems as though the pump is working, however, I noticed that it doesn't prime when the key is turned to the "RUN" position. From what I know, all cars will prime the fuel system when turned to the "RUN" position before cranking.
The pump does run while cranking and what little the car will actually run, but shuts off immediately as the engine stops runnning or you stop cranking. It doesn't re-prime or anything.
So now I'm like :wtf:
What the hell is going on with this car?!? I wish there was a better testing procedure for the ignitor. A new one costs >$400, that's a lot of money to just test to see if a part is bad.
Does anyone have any idea what's going on?
I read somewhere that I need to test voltage on certain parts and pins going to the ECU from the ignitor and whatnot; where can I get more detailed info?
PLEASE :help: !!!!
PLEASE :help: !!!!
