It's a 5S-FE with 131,000 miles. It's very scary to look under the valve cover. It's a wonder the engine can even run with such heavy deposits - they are everywhere. The rocker arms look like they have been dipped in molasses. The stuff has consistencies ranging from gooey to hard rock-like. Recently did timing belt service and replaced the front seals (crankshaft, camshaft, oil pump and cover o-ring). Also replaced the valve cover gasket. No oil leakages at the present time. However I'm very concerned about the sludge. Is there any consensus on the best way to address this problem? I would not dare to do anything to dislodge all the accumulated deposits - they would certainly plug up the oil galleys. I'm hoping for some magical method to make the stuff melt away. Any ideas? Please, do not suggest that I take the engine apart and soak all the pieces in kerosene. Ain't gonna happen.
