When I push the switch to turn on the ac, sometimes it will stay on long enough to get some cold air out, but for the most part it will start blinking, and no cold air. This is on a 2001 prius, any ideas? thanks
Wow, the system is more advanced than I thought it was. In older Toyotas the light just flashed if there was a problem. e.g. the pressure was low due to a leak or lack of freon.the 01-03 prius have the built in diagnostics system for a/c. To activate it (assume the blower are in off position initially), turn the ignition switch from off to on (without start the vehicle). press the a/c swith 3 times and turn the blower switch from off to auto.
Note: perform all those steps above within 5 sec or else it won't work.
When the step perform correctly, the system will light up the a/c light, defogger light, "max" light and the recirculate light 4 times to perform indicator check. Note: check that all the indicators light up and go off at 1 second intervals 4 times in succession.
After the indicator check is ended, the system begin the diagnostics automatically.
If there is no error code stored in, the light will have a steady fast blink.
If there is a code stored in the system, count the blinking to figure the code.
Example 1: blink blink(pause) blink blink blink equal to code 23 which is abnormal refrigerant pressure.
Example 2: blink(pause) blink blink equal to code 12 which is ambient temp sensor problem.
If there is multiple code stored in the system, lower number (code) will ouput first.
example: blink(pause) blink blink (long pause) blink blink(pause) blink blink blink equal to code 12 and 23.
Try to get the code and I will decode from the diagnostic trouble code chart for you.
Thanks, sorry for the late post, This afternoon, I will do this, and get back with you. Thanks again, wanted to say, when it it cooler outside, it works longer.the 01-03 prius have the built in diagnostics system for a/c. To activate it (assume the blower are in off position initially), turn the ignition switch from off to on (without start the vehicle). press the a/c swith 3 times and turn the blower switch from off to auto.
The a/c light blinking on any toyota vehicle for the most part is related to a/c compressor rpm sensor.
It compares engine rpm to a/c compressor rpm. (belt loose or magnetic clutch failure)
On the prius vehicles it's the a/c clutch worn out. If you look around the a/c compressor, one will notice a brown dust (like something is rusting up, and coming apart), thats a/c clutch material.
I've done a few on prius this year alone.
Hope this helps....... JM
