I dropped the pan and replaced the screen, there was quite a lot of crud in the pan and also on the magnets. Anyway, the tranny shifts and works fine, except for one thing. For example, if I'm driving at say 30mph, and lift the gas pedal, the RPM's drop very quickly. It's almost as if the transmission is not in gear/between gears. If I feather the throttle and don't let the engine drop back to idle this does not happen.
Or another scenario would be, going 30mph down a hill, lift the gas, and the RPM's drop and sometimes come back up quickly. It's like the engine is momentarily decoupled from the drivetrain. Other times the transmission will hunt, like it's not in any gear at all. This only happens when when I am not pressing on the gas at all, coasting basically. If I go say 50mph and lift the throttle, it won't happen or it seems to happen much less.
Is this an engine management problem, or something going out on the transmission? Like I said, the tranny shifts fine, no strange noises, car has good power. Going 60 or 70mph the car feels fine. Bad torque converter? I have never experienced this in a car before could use some suggestions.
Car has 90,000 miles BTW.
