Good Info, but...
Plan your passing maneuvers more accordingly.
Fresh fluid helps transmission to be more responsive too.
I don't care for throttle modules. All they do is trick the drive-by-wire to think that the throttle is further down than it is. Learning ECU becomes more aggressive since it controls how quickly the TB opens.
Btw, if engine is dirty from bad fuel/oil, or out of tune from clogged air filter or worn sparkplugs, or instigating knock sensor from bad t-stat/radiator/coolant/fuel line, then I would start there 1st.
Toyota drive-by-wire has improved. My '08 2gr has lag when punched to the floor. My '11 doesn't.
So all of this is excellent info, but likely way beyond the ability of the majority of us. I can completely agree that there's a near 90% chance people don't EVER change out their Trans Fluid as a scheduled maintenance item and if they do, it's a partial drain and fill as described over and over on this forum. (I've done this on my 07 Camry V6 and it was pretty easy and certainly did improve Trans feel, but the downshift problem remained)
I can't stress enough how incredibly simple it is to install the Weapon-R iThrottle or similar type item. It truly is plug&play. I hard wired mine to the OBD-II Diag connector's wires which was the hardest part - added a whole 10 minutes to the install. :grin:
Now as far as the "Butt Feel" our fellow TN members have expressed, I can only partly agree with this one. Yes, the trans lag is still there, but not nearly as "Butt Clenching" as it used to be making expected/planned/unplanned Freeway Passes. My 2011 Camry SE V6 was a very smooth sailing vehicle before I added the iThrottle so Toyota has certaily addressed some of the known trans/throttle issues or maybe just tuned them up for the SE model; but now with 150K+ miles on it, it is a very different & much more pleasing to drive car. I know deep down it's still a Camry and no Camaro killer, but for my daily driver, adding a throttle controller was the easiest choice.
Next up is the trans fluid exchange. This car has a real trans pan while my 07 XLE V6 did not- so still debating a full pan drop and filter swap. I really hate unscrewing and re-tightening all those small bolts. Way too many areas for small leaks. I've heard of others adding an inline filter between the radiator and trans on other cars- not too sure on that one for the Camry... Either way, the lack of filter on my 07 and it has 200K miles on it, I'd be willing to say a filter is somewhat unnecessary on modern aluminum trans. Just swap out a few quarts (typically ~3 quarts using the fill/drain bolts) every 20K miles or so and you should be good to go.
It is however really good to know there are valve rebuild kits out there. :smile:
