adding XM radio to 2019 camery LE that has car play
2.8K views 4 replies 4 participants last post by  d4nf644
I recently got a 2019 camery LE with standard radio that also have apple car play .. I would like to add Xm radio to it and have control thur the radio and still having the option to switch to car play at will.. i saw one option that used the usb port but i didn't want to loose the usb port for car play..Is there a kit out there that will fit my needs.. and if so can someone point me to it.. I also assume it possible to change the head unit but i think that higher cost..
Welcome to Toyotanation!
There is a way to install SXM on the camry. You can either buy the parts and do it yourself, take it to a audio shop or have toyota do it.
Go to this thread and you'll find the PDF.
Yea the xm app on my iphone is alway a option ..but i rather not use my iphone plan listerning to xm .that the reason having it using the xm sat is better.. but htanks for the idea.. I think the reply from Fungabriel will be my best option it a little pricy since it almost 350 bucks.. but it is what it is..
I found the Southeast Toyota Add on XM Radio Kit 00016-00917 2018 on Amazon for $99.00 and just installed it in my 2018 Camry SE. It has the same hardware as the VAIS Technlogy GSR-TY52 kit that sells for $199.00, but the Southeast Toyota kit includes a mounting bracket for the add-on pieces.
Both kits integrate well with Carplay. In order to switch between SiriusXM and Carplay you hold the mode button on your steering wheel for three seconds.
https://www.amazon.com/dp/B01M15K4AA?psc=1&ref=ppx_yo2_dt_b_product_details
https://www.amazon.com/VAIS-Technol...=1640658167&s=electronics&sprefix=vais+technlogy+gsr-ty52,electronics,86&sr=1-1
