Advice sought for avoiding gas tank/ fuel lines when installing audio amp in trunk of 03 Camry.
924 views 6 replies 5 participants last post by  meccanoble
I'll be installing a power amp in the trunk of my 2003 Camry LE, something I've never done before to any car. How can I be sure to avoid drilling into the gas tank or fuel lines? I have a diagram of the fuel system in my car but it's really vague.
Welcome to the Forum! You're on the right track being cautious about drilling back there. My first sub install in college I ran a self tapping screw a half inch into my charcoal canister under the metal cover I drilled into in the trunk. Not as dangerous as hitting fuel, but a costly mistake for sure.
I believe the EVAP vapor canister on the gen 5 is in the driver rear wheel well area, I think I saw it under there when I swapped stabilizer bushings. The gas tank/fuel lines are under the rear seat, and extend back into the trunk a little. Your best bet is to pull back the carpet and feel around. If components are under the carpet, there should be removable covers that expose them. Look under the car as well.
Remove trunk insulation panels. What it will do, it will reveal a lot of double walled metal panels for you. Ones, where you clearly see there is no components behind them. Choose one suitable for your purpose.
To be honest, not sure why you need to drill anything. I tossed floor mat into the trunk and zip tied sub to it. Floor mats have teeth on their backing, gripping to the trunk insulation. Never had sub move even a millimeter, while I could easily take it all out when spare had to be accessed.
