I have a 2002 Corolla. *About three months ago it was giving three codes. *One for a bad catalytic converter, the current P0171 lean code and the other for a misfire on cylinder #1. * Fixed the misfire code and the cat code. *
I’ve done all the inexpensive fixes myself….PCV, *Valve cover gasket, new spark plugs, fuel injector cleaner, new air filter, new intake manifold gasket etc. *No real improvement though maybe a couple of percent.
My long term fuel trim at idle during the beginning was around 40. * Took the injectors out about two weeks ago and manually cleaned them and replaced them with new rubber seals. *Long term trim went down to around 33 at idle. *Took the car to what I was told was an excellent diagnostic mechanic. *They did a smoke test and some other stuff and told me to replace the MAF and the upstream O2 sensor. *With high hopes, I replaced those with Denso parts but no change to the long term trim…still hangs out around 32 at idle. *
Interestingly, when I rev the engine to 2500 rpms, the long term trim will go down and hang out around 17-20.*If I push the rpms beyond to 3000+, the LT fuel trim goes back up to around 35…sometimes even 40. * So fuel trim improves around 2500 rpms then gets worse again around 3000 rpms. *All I can think is possibly bad fuel injectors or a week fuel pump. *Or both?*What are your thoughts? Could a melted cat also be the problem?
Sent from my Moto G (4) using Tapatalk
