I have a few small rock chips on a '14 XLE, was wondering how it went if anyone has tried it and where they got their materials. I will research when I have more time... never enough hours in the day for all I want to do.
Get some touch up paint from dealer and I use a toothpick for tiny chips and a match from a match book for med chips and the touch up brush for larger ones. As the previous poster stated less is more.
Sounds like a small chip, and the toothpick suggestion might work best, and if anything larger, do buy yourself an artists brush with a tapered fine point. The brush (or scrapers on some bottle caps) on those bottles will make you frustrated or a mess, or both.
I ordered my clear coat pen and paint colors from Paintscratch.com
The color match was fine for my Moulin Rouge Highlander, Magnetic Gray Camry, and Dark Cherry Pearl Ridgeline.
It looks like it is $29 for tri-coat paint pen for Blizzard Pearl. It is actually 2 pens because of tri-coat. The normal one color pen is around $15 with the clear coat one being $7.
Be careful though, you might find yourself spending a little more on stuff you probably do not need.
Is toyota the only place to get touch up paint? That is where I always got one for my toyotas in the past. Haven't picked one up yet for the new one. Just wondering if any other websites have a reliable match that might be cheaper.
If its something you need in larger size there is a spray paint match website. But the touchups are usually under $20 I would think, not worth risking a mismatch. I could color match it and paint it with some Hobby enamel if you like
Ebay has some xtra fine brushes for cheap. For how small chips are I might get by with regular white paint but might as well get the right stuff now and be done with it, will no doubt be getting more chips down the road ( pun intended).
For my 08 Highlander Blizzard Pearl the dealer sold me 040 White base coat and 070 Pearl Clear Coat. I just traded in my 08 for an 2015 Nautical Blue so if anyone would like these paints let me know. I only used it one to touch up a tiny chip on my hood.
I use the Toyota 070 Blizzard Pearl touch-up and Langka (http://www.langka.com) to smooth it out. Takes some patience and multiple layers after the touch-up paint settles.
Usually I get it to a point where it looks "good enough" and/or I forget about it and it doesn't bother me anymore.
I used Dupli-Color touch up pen for Blizzard Pearl (070) and it came out more "silvery" than white. It was for a large chip but luckily it was inside the rear passenger door by the step plate. I had to apply it in winter unfortunately so it's a bit of a blob. I would not recommend it in terms of color. I subsequently got the Toyota pen but have not (thankfully) had the need to use it again.
Anyone know if you can still use Langka blob eliminator after this long?
Related Threads
Toyota Forum
posts
6.4M
members
659K
Since
2001
ToyotaNation Forum is a community dedicated to all Toyota models. Come discuss the Camry, Tacoma, Highlander, 4Runner, Rav4, Corolla, Rav4 Prime and more!
