Hey there,
Ok so I've been lurking around many forums for the past years but finally my new problem has allowed me to become a registered user.
Ok Now to the problem is pertaining to my 91 toyota pickup 22re 4wd extended cab on 31's with no lift. So one day while driving my brakes start pulsating (pedal going up and down) i decide to replace the front rotors and brake pads and rear drums and shoes. After inspection of replacing the rear drums and shoes I noticed one brake cylinder was leaking so I went ahead and replaced both rear cylinders as well. I went for a drive and the problem was still there. I decided hey Ill give it a shot and replace the calipers as well and try a different set of new rotors. Problem was still there finally I resurface the brand new rotors (someone had the problem of pulsating rotors on another forum same truck and upon research that person got their brand new rotors resurfaced and it helped out) anyhow the problem is still there. So basically everything has been changed except for the bearings but the bearings are fine. Have any ideas? Help will be greatly appreciated.
