www.bobistheoilguy.com
Sift their forum to find the ongoing AMSoil life test.
The basic outline is anyone, with any vehicle, of any mileage is welcome.
Rules:
The oil MUST be analysed periodically
The oil is NOT to be changed until an oil analisys says the oil is breaking down.
Oil consumption is normal. Keeping the oil topped off with fresh is OK.
So far there are a few cars using AMSoil already over 45,000 miles, one over 60,000 miles. Without a single changing...
You're not suppose to switch to synthetic if your vehicle already has a decent amount of mileage. Doing so will cause leaks to the engine seals because synthetic is so much thinner than dino oil..
That's completely incorrect. Anytime is a good time to make the switch, and years ago was the best time!!!
It's as bad as the "Don't swap to synthetic, because the old dino, and the new synthetic oils will mix". That arguement is ludacrist. So they mix? So what, people use to think that it would mix and produce 1.21 gigawatts through the flux capacitor and the HALO weapon would fire, destroying out corner of the universe!?!?!?!?
If the seals are busted, they will leak. If they are still in good condition they will not.
Guys the type of oil
DOES NOT cause the seals to leak. If synthetic oil leaks from a seal
THEN THE SEAL was ALREADY BROKEN BEFORE THE OIL WAS INTRODUCED AND SHOULD HAVE BEEN REPLACED. Dino oil simply isn't leaking
YET. The problem is already there regardless of synthetic OR dino oil.
