I purchased a 1998 Toyota Camry at the car auction and it does not have the transponder key. I have an aftermarket key which opens the door, it also turns the ignition, but the car will not turn over. When you turn the key the motor cranks, but no start. I have replaced the starter and still same problem. We have tried to spray starting fluid in the air cleaner compartment, but it sounds like it is trying to start but doesn't. I found a fob in the trunk and replaced the battery, still nothing.
Does anyone have any ideas, aside from spending $250.00 from Toyota for a transponder key on a $550.00 vehicle? Do you think that it is the alarm or something else? I would appreciate any ideas. Thanks for your help!
