However, I found something better and cheaper: Fremax rotors. They are made in Brazil (NOT China!!!!!!!!!!!!) and they also have painted hubs for rust deterrent, plus you don't even have to clean them off for installation. They are also sold under the name VGX Platinum, and available on eBay from seller autopartsource. Just enter "autopartsource rotors [year] Camry")
I have C-Tek rotors and Axxis Deluxe pads on my car now, but the uneven pad transfer is starting to shake the wheel when I stop (commonly mis-called a warped rotor). I'm going to replace them with Fremax rotors and Akebono pads.
@bgmbgmbgm: How much are those Fremax rotors and how are they doing?
I'm also suspicious that the Centric Premium rotor with E-coating is just the regular C-Tek with the added E-coating. I don't live in an area with snow or salty roads, so I don't think the E-coating would really benefit me
I'm also pretty confident that the Premium is just the C-Tek with the E-coating. However, I do find that coating to be useful with staving off the rust.
i like the premuims. To me they look like a different type of steel the coating does seem to help with the rust.
Yes,
I ordered both for science and noticed a subtle difference in machining.
The Premiums had a better finish, beveled edges and the ORielly guy who checked both sets of rotors for balance and runout mentioned the Premiums were built to tighter specs.
Curious, I asked the mechanics I work for what the difference is and they said there would be no practical difference save for noise and life.
In theory, the Premiums would last longer, be resilient to rusting and make less noise.
In practice, they said if I installed then myself and drove in SoCAL, the Premiums would be a waste of money. They could see why someone in a more rust prone state might get value out of it.
I then experimented with both sets: I could not feel much of a difference between the Premium and the $10 rotor so after a month of experimentation, daily driving, I moved out and installed the Premium on a customer vehicle to recoup the cost. She was extremely happy to pay $17 for each of them as she was used to paying multiples of that and I recovered half of my investment.
In the end she gave me a $30 tip so I guess I got all my money back and some more. I think she googled the part numbers and decided they were cheap enough to pay in full because they were practically brand new.
I also used them with AutoZone brakepads and while I initially thought the free AutoZone warranty would be an excellent value, I dont see using the free warranty at all.
The C-Tek pads are HALF the price of what AutoZone charges so for me to break even I would have to do ateast two warranty replacements - which spans a period of over 7 years!
Of course I could have just listened to
@JohnGD when he said I would come to the same conclusion momnths ago:
https://www.toyotanation.com/forum/...-solara-1999-2003/867817-centric-brake-rotors-two-questions-2.html#post13418354
Keep in mind that I am the guy who installs eBay control arms and struts in my Camrys so I am easy to please.
My current favorite choice for brakes are $16 C-Tek pads w/ HW (30105620 (301.05620)) and the $16 C-Tek (12144078 (121.44078)) rotors.
LESS THAN $50 ALL IN for a complete front set that includes brake hardware.
I have purchased and installed these sets on over a dozen Camrys now and only ONE Camry has a brake squeal noise - the one I drive because I did a quick hack job and not rebuild the calipers properly and it came back to bite me as it should.
I took the risk because I knew I could fix it if I needed to which is an option I dont have on the other Camrys. I gambled and lost so I ordered the Caliper Repair Kit 14343004 (143.43004) and the CARLSON 16078 Pin Boot Kit Front; Disc; D562
After I am done with the current CV Axle job for a customer I will have time to redo my brakes in October and the squeal will be gone for good.
