I recently bought a 2015 Highlander, my first Toyota in nearly 30 years and I have added some items to it. One of the items is a dual-view dash cam. I have all the wiring already run in the headliner and behind the A-Pillar down to the fuse block. Originally I was going to ask how was the best way to tap a fuse, but I found a post on here already that shows the great fuse tap option for these mini-fuses (Some Information I found) using a Cooper Bussmann Fuse Adapater (part # BP-HHH-RP or 8553414). I'm going to be picking this up tomorrow, as I much prefer to tap a fuse than tap a wire directly.
Which brings me to my question, in the fuse block under the dash, which fuse is one that has a constant flow of power through it. I need to have power to my camera all the time. It has a parking feature that will turn the camera on and record if it detects movement and such. The hard-wire kit has a battery protector shut-off that will prevent it from draining the battery, so I need a constant hot. Once, I finish this install tomorrow, I will be posting photo's, just wished it had not rained or I would have taken photos and video of the installation, including the removal and installation of the A-Pillar cover.
Thanks in advance.
Thanks in advance.
