I had already performed tests 3 & 4. And it's within specs. I did find exposed wire on injector terminal
#1 and rewired it. The others were visibly OK. I'll do the wiggle though. Wiring is old and I will end up having to rewire the whole engine bay, I'm sure.
Toyota recommends .032 spark plug gap, but since I'm running 18psi of boost, I use .030 as recommended by some guys who run hi boost to compensate for the extra fuel and wetter environment in the chamber. But I will try it.
The plug wires are new, but not OEM, so given everything thats happened, not trusting the brand.
The cap was new(not OEM), but faulty. The FPR was new(not OEM), but also faulty.
So I will check that too.
