During a recent replacement of my lower control arms I noticed that the steering boot on my passenger side was torn pretty dramatically. I had just gotten an alignment and didn't want to pay for another after monkeying with taking the tie rods on and off which lead me to an interesting product.
Enter the Rakboot. http://www.stretchcvboot.com/rakboot/
Pretty simple.. just a boot built to stretch over the ball joint on the tie rod end so you don't have to take the tie rod apart. The company is Australian I believe so it takes a little longer than usual to get the part.
Before pictures (yikes)
Ok let's replace that
First step is to get the outer tie rod end freed. Remove the cotter pin from the castle nut and spin it off with a 17mm
Next up, grab a big hammer and hit the ball joint hard a few times. This should pop the tie rod lose and you should be able to remove it with your hand.
Remove the old boot and discard.
Clean up any junk that may be on the now exposed shaft
Now is where the rakboot shines. Slide on the "raksok". Then cover the outside in some engine oil (or similar) to get it slippery.
Slide the rakboot on according to the instructions that it comes with. Pretty soon you'll have it all the way on.
Slide the rakboot onto the end of the rack and secure. The kit includes zip ties. I used a beefier one on the rack side and used the included one on the ball joint side. If you don't feel comfortable with zips, use another type of clamp to your liking.
Now you're ready to button things up. Put your tie rod back into place and install the castle nut to a torque of 46 ft/lbs. Replace cotter pin. Enjoy a simple boot replacement with no alignment necessary.
