Driver side has dimmer DRL than the passenger side.
1 reading
6.5K views 12 replies 5 participants last post by  Camie18
Long story short, two months ago, some idiot driving by had their door caught on to my drivers side bumper ripping it off. : (
After its been fixed, i notice that the driver side DRL is now dimmer than the passenger side. An advisor had a Toyota foreman look at it and he replied saying that its correct because the driver side DRL should be dimmer than the passenger side. Even the low bean should be aimed lower than the passenger side.
I dont recall seeing the DRL being dimmer before the accident nor was the low bean aimed lower. Its aimed lower in a way that its obvious and annoying to look at. when driving at night.
Can anyone confirm this? Thank you
The mechanic who fixed the bumper had to replace the entire headlamp, the headlamp is also confirmed genuine
302981
In my experience the driver's side should indeed be aimed slightly lower than the passenger side. The reason for this is so that it will not be as distracting to oncoming traffic. Dimmer, however, is another matter. I've not heard of a driver's side that is intended to be dimmer than the passenger side. Maybe it's something new in your generation's design? I'm no expert so wait for further word from those more familiar with your vehicle.
Yours is not a rare car... try to keep your eyes out for same-year/same-headlight examples and try to compare with regard to brightness. The fact that you didn't notice anything prior to the bumper mishap indicates it may be more than just a coincidence. For the brightness, have you checked the voltage at each DRL to see if there is a difference? I can understand how the accident could have caused damage to the wiring harness. As for alignment, hopefully someone here knows the alignment specs. On my vehicle, the driver's side should be aimed about 1" lower at 25'. I'm assuming that the alignment is done on the low beam and that the DRLs are fixed relative to them. Once again, I don't know this so wait for someone with first hand knowledge.
#3 · (Edited)
it is true that the driver side headlight is aimed lower so it won't blind oncoming traffic. But being dimmer? i don't know about that one.
I should add that its the headlight that is adjusted to aim low.. not sure if they lower the DRL light too. I personally don't think so. Though when you adjust the headlight, does the whole headlight assembly move or just the light bulb?
I would have the headlight wiring checked to ensure a part of the harness is not pinched or nicked from the accident. High resistance limits current flow and that could cause the light to be dim.
I dont see any reason to make one dimmer than the other, but as far as my headlights are, the brightness are symmetrical. The driver side beam is however tilted slightly vs the passengers headlight beam so it doesnt glare into oncoming trafficc. Bugs me that it is slightly slanted though, and bugs me i cannot throw hids in. Not a fan of leds
If the lower aim bothers you a lot, you can adjust your left headlight to be even with the right side. There are adjusters to adjust the beam. Just park it facing a closed garage door or wall so you can level it out.
#9 ·
You're right. I've tried seeing the difference between turning on the low beans with the drl on and then comparing it to just having the DRL on. It's about the same brightness. I'm not a mechanic or anything so trying to see if the wiring is turned around is gonna be difficult. Any ideas how to check? Or would it be that the new entire headlights installed is just dimmer than the stock 2018 headlights?
