Front Transfer Case Fluid Change (AWD)
47K views 6 replies 6 participants last post by  sweeneyp
What's the procedure for draining & refilling the front transfer case? I've read the thread on the transaxle fluid change. I understand that it uses ATF WS which is p/n 00289-ATFWS.
Also, what's the p/n for the drain plug gasket & fill plug gasket. I believe they are the same 12157-10010.
Thanks.
What's the procedure for draining & refilling the front differential? I've read the thread on the transaxle fluid change. I understand that it uses ATF WS which is p/n 00289-ATFWS.
Thanks.
i'm there with ya on this one, however you may not get a response as i don't know if anybody has tackled this. it's sure not like the old days.
Thanks.
Not sure if this will help, it is for 2nd gen HL but might give you some idea of what is involved.
http://www.toyotanation.com/forum/1...generation-2008-2013/318276-diff-transfer-case-gear-oil-change.html#post2959747
I'm going to change the front and rear differential fluids as well as the transfer case fluid in the next few months , once i get to 32,000 km because the manual says to (if your towing ). And because i don't know how and the vehicle is under warranty , i'll let the dealership do it. I hope they don't %^$@#$^%^ it up !
You have a rear differential fluid, a transfer case fluid, and the automatic transmission fluid. There is no front differential fluid as its part of the automatic transmission(transaxle).
The rear differential fluid and transfer case fluid are both synthetic 75w85 GL5 gear oils. You can use 75w90 GL5 synthetic gear oil. For both of these, remove fill plug and then remove drainplug. Replace drain plug gasket, clean, reinstall, and torque drain plug, refill until it just overflows(vehicle must be on level surface), and then replace fill plug gasket and reinstall/torque it.
The transmission fluid for the 6 speed is Toyota WS. There are various synthetic LV equivalents from most of the fluid companies. It requires an OBD scanner to measure temp to check the ATF level. And, you can do a cooler line fluid exchange with whatever quantity of ATF you purchase. There is an ATF pan plug to remove which has the screw in check level straw. Once ATF temp is correct, you fill until it just overflows from the 'straw' in the ATF pan.
The viscous AWD magnetic clutch is not serviceable.
The service of these components is typical of any AWD Toyota(Matrix, RAV4, Venza, and earlier Highlanders). Shouldn't be a problem for any competent tech. Service writer might be clueless. Had to argue with a service writer who refused to acknowledge that there was a separate transfer case. And, they didn't have a clue on how to exchange all the ATF via the cooler line method with or without an ATF flush machine. Pan drop partial fluid change only. Dealers really aren't impressing me with their incompetence.
Misinformation in this thread and makes me recommend that both users hire a mechanic or do more research in servicing their vehicle, as the dealer may not perform all the services you want, or even do it correctly. Watch them!
https://techinfo.toyota.com/
#7 · (Edited)
Just get a quart container for the transfer case and rear differential each.
edit: just re-read your first post....
Double check what parts are what :thumbsup:, ATF-WS is ONLY in the transaxle (that contains the front and center differential)
The typical part sites I use don't even list that part, your local dealer part desk should stock it though, it'll be a common part.
