AlaricD, do you own a 2nd gen camry?
if you do, i'm sure you can appreciate the poor quality of lighting our stock headlight system provides. i personally find them extremely dim compared to soo many other cars on the road (given our car is roughly 20 yrs old now) and it feels very dangerous. i also think many other 2nd gen camry owners agree to different degrees with our comparatively under lit stock headlight system.
No, but I don't need to-- I know it uses the 9004, which is a horrible joke perpetrated on the American driving public by the Ford Motor Company. All it gives is a long service life. Headlights based on the 9004 need to be very large to approximate working well, and even then you don't get very good beam focus. (Yet they can be made to conform to FMVSS108!) (However, while BAD headlights can conform to FMVSS108, there are no GOOD headlights that do NOT conform to FMVSS108, unless they instead conform to ECE regulations.)
I also have a friend with an '89 Camry, and, yes, my subjective opinion is that the headlights just don't cut it. The headlamps are WIDE, but not very tall, and the transverse filament would benefit from a taller headlamp assembly. Also, I think his car is an excellent candidate for relays.
There are (legal) upgrades available in the form of the
GE Nighthawk Platinum or the
Philips Vision Plus 9004VP. Avoid bulbs with blue tint or promising higher color temperatures or "whiter" light. A large portion of a halogen filament's output is in the yellows; filtering them out just filters out light.
i am very open to hearing what other owners of my same built vehicle have found to help resolve this issue. just because one person chooses to break their local law (noticed a people posting from all different US states and even Jamaica in this thread), doesnt mean we will all follow. i appreciate him sharing his experience and opinion. i would also appreciate you sharing your experience and opinion with different approaches in dealing with our stock headlight system in the 2nd gen camry...hence the topic of this thread.
I forget if the lenses are glass or plastic; if plastic, polishing and recoating the lenses could make a world of difference. Doublehorn Products makes an excellent kit for that purpose.
Also, installing a set of high quality
relays will ensure the bulbs get every volt they're entitled to. That can make a world of difference right there, as the brightness changes to the 3.5 power with the change in voltage. The 9004's low beam filament produces 700 lumens at 12.8V (the rated output voltage). If you're not getting 12.8V to the bulb, you're not getting good lighting. If you're only getting 12.4V, you've dropped down to 626 lumens. If you can get it to 13.1V, that's going to get you 760 lumens. The high beam filament produces 1200 lumens at 12.8V, so once again relays can get you closer to 13.1V and 1300 lumens. Not a giant difference, but it does add up. While the factory wiring was probably at one time barely adequate, given the car's age, it probably isn't close to that anymore.
Aiming the lights properly is also a help.
I'm also not opposed to installing a set of properly designed auxiliary high beam lamps ("driving lights" in the vernacular). As auxiliary high beam driving lamps, they are to be used only in conjunction with high beams, and away from traffic.
The Cibié airport series 35 is a rectangular lamp (to better match the rectangular headlamps on that Camry) with a chrome housing, and one version provides a white driving beam (again, to be used
only with the high beams). Unfortunately, they're a bit pricey (but you pay for quality and guaranteed regulatory compliance). New York's code isn't clear to me on whether these lights will be permitted; however, if installed to not interfere with FMVSS108-mandated equipment, it shouldn't pose a problem (unless used unwisely).
Proper fog lights only project a beam about 25 feet in front of the vehicle, making them useless to "supplement" low beams, especially at highway speeds.
