I have a 1996 Tercel with 144k miles, unknown service history, and 4 speed C141 manual transmission.
It's difficult to put the clutch* into first gear, but only when shifting from neutral into first when the car is moving. In other words it shifts okay into every other gear. It will easily go into first gear if I first shift to second, then shift into first. There are no other problems, e.g. no slipping and no popping out of gear
I did the following without improvement in the neutral to first gear shifting problem:
switched from Mobil 1 GL-5 to Red Line MT-90 GL-4 gear oil.
bled the clutch fluid
changed the slave cylinder (clutch fluid had black particles and was dark).
verified correct clutch pedal height
Thanks!
* I'm unsure of the correct term to use
Thanks!
