How do I activate ECO drive mode in my 2013 Avalon?
7.7K views 6 replies 5 participants last post by  lE5QE0
I have a Toyota Avalon 2013 xle. It doesn't have the ECO mode botton but it activates by it self ( I see the green light display on the dash) . I need to know how to on and off it by my self. Someone should please help me.
I don't know if this will help from my manual.
â–  Changing the settings
While the vehicle is stopped,
press the “DISP” button until
the “Settings” screen appears.
Press and hold the “DISP” button
while the “Settings” screen
is displayed.
Press the “DISP” button to
select the desired setting item.
Setting up the displays
Item Default setting Customized setting
Digital speedometer On Off
Units (vehicles without
a navigation system) English Metric
Turn-by-turn navigation
(vehicles with a
navigation system)
On Off
Eco Driving Indicator
Light Off On
I have a '13 XLE Touring. It has an ECO|NORM|SPORT button. If memory serves, the model you have will determine which switch setup (if any) you have. These buttons will change gas pedal responsiveness, shift points, steering response and HVAC output.
From my Owner Manual:
285660
The settings that arh refers to is to turn off the "ECO" indicator light only. It doesn't determine whether or not the car will go into ECO mode, it just enables or disables the "ECO" light which would display inside the tachometer. The car will automatically light this up (if enabled) when you're not heavy on the gas or going uphill.
