Okay, I've got ANOTHER problem with my 1997 Camry. A quick history. I've been doing a lot of work on this car lately. It started with a blown head gasket. I took the entire engine out and got the head resurfaced and the block checked for flatness. The transmission was making a bad noise so I replaced that at the same time. When I put it all back together again I had a few problems. It took a while but I'm down to one problem left - I hope.
The intake camshaft is leaking around the seal. The first time I put the new seal in I buggered it up when I used a press to push it home but thought it would be ok. It wasn't. So, I took it apart and put a new one in being very careful to seat it just right. This time I took the valve cover off and removed the end-cap. That made it very easy to insert the seal. Everything looked good, but when I started the engine it leaked again - not as bad as before but bad enough.
Has anyone tried this method of replacing the seal? If so, how did it go? If the seal is seated properly I'm worried the leak may be caused by bad scoring on the camshaft. If that's the problem is there anything I can do besides replacing the camshaft? 🙏🙏🙏🙏
