I've already searched.....Want to know how to relocate the O/D button!
2.5K views 16 replies 10 participants last post by  coolchu001
Updated: O/D button relocated!
Just wondering how i can relocate the button....can i just add an extra length of wires to it and the reroute it somewhere or do i have to pull the wire from under and then relocate?
4/24/05
Just relocated my O/D button today... took only like 40mins. If anyone needs help on this topic I'm glad to help. Oh as of cost.......$1.97+tax! for the toggle switch with illumination! where will i be without walmart?!
I took apart my stock shifter to get the button and wires out on my 96. I don't remember having to extend the wires, and I mounted it right "under/next to" the ECT/PWR button so I didn't have a problem with the wire length.
#13 ·
well currently my stock shifter is quite ugly looking....the top is all peeling off and shit....so i want a new one....i've tried like 2 or 3 brands already.....either they are too short or the inner diameter's too small....oh btw.....do anyone know what the stock shifter shaft's diameter is?
#14 ·
coolchu001 said:
wouldnt you want to pull the wires from underneath and then relocate it....or else the od wires will be showned
If your new shifter has a button/switch on it, you don't need to pull the wires out.
But if it doesn't have a button/switch, pull the wires out and wire them to a switch.
I used a mini spdt (single pole double throw (3 prong) switch).
P.S. If you use a spdt switch, use the center pin and one of the outer pins.
#16 ·
It's really easy to do. When I changed my shifter I just bought a toggles switch and put it right under my ect button. People always ask me what's the button for. I tell 'em it's to self-destruct.
