Factory Hitch Install
Thanks for everyone's tips on this thread.
Okay, finally decided to order the factory hitch from toyotapartsstore.com and bit the bullet on trying to install it myself ($440 with shipping). The Toyota dealer price was just too expensive. I did not order the harness kit since I'm only planning to
tow a 4 bike platform rack. I could always install the harness kit separately in the future. The box came a little beat up with one of the ends busting through the box slightly. Luckily no serious damage.
All in all, it took me and a couple friends about 3-4 hours of work. I'm not a real mechanical type and was a little novice about the required tools (i.e. I had to research about what a
torque wrench was and borrowed one..great tool). I ended up using a jig saw for the plastic covers under the car (free handed the required cut-outs with side-walk chalk). I'm so glad its done.....l'm very happy with the install. I decided to order the exhaust tip as well since I was down there anyway. It's definitely a DIY project.
Some key learnings:
1) Have 2 guys under the car to lift up and bolt in...would be great to have a 3rd person hold up the middle while the bolts are hand screwed in to alleviate some of the pressure
2) Take a good look at how the plastic moldings fit relative to the car body parts (take a picture if you have to). It was confusing for me when I tried to reinstall the plastic moldings because I couldn't recall how they were positioned and which screws went where
3) Save the screws, bolts, etc. in separate sandwich bags for each area
4) If you have an exhaust tip, remove it before installation
5) I got confused in the instructions (step 3d) where it ask you to remove rubber drain plugs on the L & R. There's some exposed drain hosing on both the L & R for moisture build up or somethinng. The instructions are not referring to those drain plugs, it's simply the rubber plugs that are in the factory pre-drilled holes...
6) The holes in the hitch for the bolts have some give (left and right) in terms of what position the bolts tighten onto the hitch. The instructions ask that you center the bolts as much as possible. I was so busy trying to get the bolts in I didn't do the centering. If you plan to tow a trailer, I'd imaine you would definitely want to do the centering so that the hitch is as centered as possible for serious
towing.
Here are some before & after pictures:
BEFORE
DSC_7441 by
Texas Tongs, on Flickr
Hitch and Contents
DSC_7443 by
AFTER
DSC_7467 by
Got to put it to use recently:
DSC_7558 by
DSC_7597_edited-1 by
