Spare Key
Is it true that a new key for a Venza will cost approx $350 - $400 for the key and programming?
If you go through a dealer. You will find the FOBs on eBay but it will still cost about $75 to program it and if you need a new physical key cut figure another $75. I had them throw in a spare FOB when I purchased my Venza. I also had them include a spare on my previous two smart start equipped Toyotas. Never used any of them.Is it true that a new key for a Venza will cost approx $350 - $400 for the key and programming?
Bring the fob back to the dealer, play dumb, and say "fob no work". They should make it good under warrantee unless there are obvious signs the fob was drowned. Odds are the dealer would replace it anyway.Well, we just bought a new 2009 Venza off the show floor, we get home and my wife decides to wash the jacket I had been wearing and sure enough, the key fob was in the jacket pocket. I immediately took the thing apart, dried it the best I could, and then put the pieces into a bowl of rice to let the rice absorb the rest of the moisture.
After two days, I took the pieces out of the rice and reassembled the key fob only to find that it no longer works on our car. The little light on the key fob glows brightly when I push the buttons so it makes me think that the key fob itself is okay. I'm thinking that it was shorted out when it got wet and I'm hoping that it just needs to be reprogrammed.
The dealer charges $68 to reprogram the key fob and I'd rather not have to pay that so I'm looking for the reprogramming procedure. I've found the procedure for older Toyota vehicles but nothing for a 2009.
Please help me if you can.
Just to be clear... Did you replace the battery on a fob that came with the car but stopped working, or did you replace the battery on a fob that you bought on eBay?:dunno:I too was told $450 for a new fob from the dealer. I found others on Amazon / Ebay for $150-180. I told the dealer and they said ok no problem, just bring it to us to program it will be $70. So before I did this I opened up the fob just to have a look. It has a circuit board that you can pop out and there is a small button battery. So I went and got a new one at an electronics store for $7 and popped it in. Low and behold this solved the problem, the fob works like a charm. NO PROGRAMMING REQUIRED. IT IS ALL A COMPLETE SCAM. THE COST TO FIX IS $7!!!
