Matrix XR 'jumps' around on roads
1 reading
8.2K views 17 replies 6 participants last post by  Girma
I recently purchased a 2004 Matrix XR (AWD). Only 118K miles and runs great. But when driving over small bumps or normal asphalt repairs on roads, the car seems to slide or jump sideways in the rear. Could it just be the AWD: the front wheels lose some contact and the back wheels suddenly grab, causing a sliding feeling?
I did get a 4-wheel alignment done yesterday and it seems to be better, though I haven't tested it out on older roads yet. Could struts be an issue? Or some other suspension part? There is a bit of a 'normal' roll of the chassis side-to-side on a bumpy road. Just wondering if others have had this sliding-jumping rear experience with their Matrix XR. Thanks.
A more careful inspection of the 2004 Matrix XR AWD shows rear shocks that need replacement. Am hoping this caused the jumping in the rear over bumps. Anyone know if the Quick combo - springs and shocks - are available for the rear in an AWD? Or is it possible to just replace the rear shocks without compressing the springs?
Thanks. I see that so many of the companies specify their Quick struts for the rear are for FWD. So when I see a company with a Quick strut for the Matrix rear and there's no specifying AWD or FWD, I'm leery that it will actually work for AWD. But like you say, there should be some available.
I went to get some new rear shocks installed after seeing that one leaks. I was told that the control arm would have to be removed and that means an alignment would be needed. Since that garage doesn't do alignments, they didn't do the rear shocks. Make sense...but I wonder if they might have been looking at the front instead of the rear. To replace the rear shocks, does the upper control arm have to be removed?
#11 ·
I would be very surprised if you had to remove control arms to get the strut out. Maybe undo the ball joint to allow removal room. But the whole arm? Hopefully someone here has had the pleasure of pulling them.
The obscenities I've yelled at some awd vehicles when trying to remove rear cv axles on the other hand ...lol.
#13 ·
This what your rear suspension looks like;
285710
I'd strongly suggest to check "control arm" bushings as they control side to side movement of the entire assembly. Along with the torsion beam bushings. Struts normally simply give very bumpy ride but not really side to side wobble. Strut is up/down, trailing arms and "control arms" are side to side.
List as follows:
2-API 270097342 Sway Bar Link Or Kit; 4 WHEEL/ALL WHEEL DRIVE,COMPLETE - REAR; Base Model
2-ULTRA-POWER K80230 Front; Base Model
1-MONROE 172116 Quick-Strut Front Right
1-MONROE 172117 Quick-Strut Front Left
2- MONROE 71375 OESpectrum Strut REAR; AWD
2-MONROE 904990 Strut-Mate Strut Mounting Kit Rear
#16 ·
Very helpful comments regarding my Matrix swaying/'jumping' a bit over bumps. Changing the rear shocks did help quite a bit. Now with snow and ice, the side to side movement is still noticeable.
My son has the car now and he looked and saw that one of the rear upper control arm bolts was loose. The control arm could move or shake. So the comments above about control arms/bushings are right on. Thanks.
The control arm bolt broke when he tried to tighten or remove it. But here's a question: If the bushing is worn, I see that there are control arms that say specifically "For Matrix AWD". These have a special adjustment end on the arm in case the Matrix AWD is hard to align for various reasons. Does an AWD Matrix require one of these special rear upper control arms?
#17 ·
The awd matrix and fwd matrix have completely different rear suspension. I'd assume it's needed...
