This has annoyed me forever and I finally decided to do something about it.
The problem is the cap itself. It's a crummy, cheap design, and when the coolant sloshes around it leaks out of the top. Then there's the drain tube to vent pressure. It just pukes coolant on the top of the tank, and it drains down and makes a mess in the engine compartment. What were they thinking?
I looked around to see if I could come up with a fix. I found some rubber stoppers that I had used for feet on another project, and much to my surprise they fit perfectly.
Plugging the hole is one thing, keeping the plug in place was another thing all together. I tried various things, all came up short and looked real ugly. I needed some way to remove the plug, so I thought of attaching a knob of some sort, and then I got the idea to use an eye bolt. This would give me something to grab onto, and I could fasten it securely by drilling the rubber stopper, and fastening it with a nut. Here's what I came up with.
Now I had to figure out a way to keep the plug in place. I thought about zip ties, bungie cords, all were lame. Then noticed that the plug with the bolt in it, stuck out farther in the hole that without the bolt. Hmmm, seems that the plug expanded when I inserted the bolt in the rubber. Taking advantage of this, I removed the washer that I had on the bottom of the plug and let the nut bind into the rubber. Then I could insert the plug into the hole with no threads engaged on the bolt. After it was in the hole, I just had to turn the eye bolt clockwise and the plug would expand and lock it in place in the tank. And as an added bonus, by tightening up the bolt, it would also secure the nut tightly so it wouldn't come loose, and drop in the tank.
Here's the before and after picture.
And finally to address the pressure vent. This was pretty simple I just used some plastic tubing that I had left over from the PowerBleeder and jammed it inside the hole of the vent. It's not a straight shot, and has a little bend so by jamming the plastic tubing into the hole in the tank as far as I could, it seemed to be pretty secure. Then I routed the plastic tubing through the ABS tubes, under the wiring loom, and then through the hole where the Windshield Washer fluid goes. And finally, I had to check the clearances between the top of the eye bolt and the hood. Fortunately there is a recess in the hood lining for the stock tank, and there were no clearance problems between the top of the eye bolt and the hood. I'm pretty sure that this will solve the leaking problem.
Here's what it all looks like when it's finished.
