MIce in heater blower, where is the intake?
1 reading
12K views 24 replies 8 participants last post by  75aces
Mice keep building nests in my heater. I would like to screen off the intake opening, but have no idea where it is located. Any help? Is there some sort of repellent I can spray into the blower ?
First of all you should always leave the fresh/recycle lever set to recycle every time you park the car. This closes the plastic flaps to the outside. Now you can argue that mice will chew through the plastic, but I doubt that. They have no reason to put the effort in to chewing through if they don't know what's underneath.
If you really want to get to the air intake then remove the plastic cowl and you will see it above where the blower fan is. To remove the plastic cowl you need to remove the wiper arms first. They are just held on by a nut but they can be stuck on the splines, so be careful pulling them off.
You could remove the blower motor case and install it that way. A lot of work though.
The mice did get in because you didn't have it on recirculate, no? Why not just keep it set to recirculate and see if that solves the problem?
If the mice actually did chew through the circulation control flaps you could see that if you remove the glovebox. The flaps are visible from the air intake opening behind the glovebox. If they did you might want to disassemble and replace the parts anyway.
Reactions: Apples555
#9 ·
The best way to solve the mouse problem is to put sticky boards in the area where you believe they are coming in, you can get them at any hardware store. I did pest control for a couple years and I've managed many apartment buildings, sticky boards work great, ( they attract rodents because of the peanut butter smell). They even have some that fold into a triangle tunnel. The one's for rats are the best. "Caution" try not to touch the sticky part of the board!!! There is no poison so they are safe to use without worrying about other animal's.
#11 ·
Is that a feral cat?
I notice that cats don't much like to lay on cars newer than the '70s or '80s, probably because of the aerodynamics which require sloping hoods...
Notice how the cat is laying longitudinally on the hood, and up at the top where it is more level.
Yes, feral, but trapped and released (spayed or neutered). She had 3 kittens in the backyard a few years ago. All trapped and released. They clip the tip of the left ear to show they've been fixed.
They usually like to go on the roof of cars where it's flat. I think the metal carries the heat away or cools down quicker than the ground on the hot summer evenings.
#14 ·
There had been a lot of white with black spots cats in the neighborhood in the last few years, but before that solid gray, solid black, a mackerel tabby cat and others.
Reactions: Pete Suhman
#21 ·
What do mice think? "Hmm, so what about this big moving thing that the human seems to care for? Shall I invade it as well?" Can't have nothing nice.
Like a certain entity that I don't believe we are allowed to mention, but rodents come only to steal and destroy.
If you have ever seen when a cat catches a mouse, it is entertaining. No human fight comes close to being as violent.
Good kitty.
#22 ·
Mice are more of a problem in cars which have sat for an extended period of time, especially if they are parked off of the pavement and near either a field or a building which has a mice problem.
They tear up upholstery and foam, they chew up wires, and they piss and crap everywhere which causes more rust.
Hate them meeces to pieces...
Reactions: 75aces
