Uhhhhh OBD2 is a standard communication interface. If you’re looking for basic vehicle stats and engine code reading, any OBD2 scanner will work fine.
Oh no. You should be fine. In the repair manual it says to re-calibrate the steering sensor zero point, but you need the tech stream device and software for it.
Hmm, great and thank you for the device recommendation.
I have printed out a portion of the Corolla service manual from the Toyota TIS and they often make referral to their Techstream software...I suppose it's a web based software that needs active subscription?
Actually, no. You need a subscription to keep it up to date of course, but you can download the local copy as long as you have a TIS subscription. Then, you just need an adapter that is compatible with the software.
Autel MaxiLink ML329 OBD2 Scanner (Advanced Version of AL319 Code Reader) Reads and Displays I/M Monitor (Emissions) Status with AutoVIN Function in Code Readers & Scan Tools.
ToyotaNation Forum is a community dedicated to all Toyota models. Come discuss the Camry, Tacoma, Highlander, 4Runner, Rav4, Corolla, Rav4 Prime and more!
