I have a 2012 Camry with approx 113K KM on it and was thinking of doing a coolant flush and change the thermostat. I believe on my car, the coolant can last up to 160K KM. As for the thermostat, I recall reading some time ago that changing the thermostat helps with heating up the car interior faster on cold days. When I had my old 2002 Camry LE V6, I used to change the coolant every 32K KM and changed the thermostat around 100K and never had a engine cooling issue and the car heating was awesome. I figured I can follow the same logic for my 2012.
Has anyone else done the coolant/thermostat change at the same time? Also, what else should I do at 113K KM? I have already changed the transmission fluid around 90K KM with a drain and fill and Toyota replaced my torque converter and changed the entire fluid as well. My brakes were serviced 20K KM ago last summer.
Thanks
Thanks
