Road noise reduction
1 reading
39K views 76 replies 27 participants last post by  eastcoast1989
We purchased a 2021 Corolla XSE in Oct 2020 and are very happy with it. Fun car to drive, sporty, great gas mileage with reasonable power considering. I'd like to reduce some of the road noise and am interested if anyone has done this. I'm not sure if I should address the outer doorskins first or what. I do have some left over Dynamat type material left from another vehicle. Any info is appreciated.
Yes, you will get the most bang-for-your-buck with installing CLD on the doors. I'd recommend to treat both the outer and inner skins.
I too bought a '21 XSE Hatch and the rough freeway roads finally got too much just hurt my ears. What I did was buy cheap floor mats from Ross $10 for a set and put them under the Toyota mats. Also had some thick stairway step rugs which went under the seats and under spare tire. Bought some of this stuff from Amazon and put one under each mat. I also took the spare tire out and installed the remaining sheets everywhere I could. This probably reduced the road noise by 15 to 20 percent. The freeway is still loud but my head no longer buzzes afterwards!
#37 ·
Don't let your gas pedal get stuck using two mats 😂😂
u can take ur doors panels and apply dynomat to it, it will help big time, do the same thing for ur trunk and trunk compartment and spare tire compartment. i did that for my 90 corolla gts, it's a 30 years old car and the old sound deadning was just done, i use something similar to dynomat, did my door, my trunk, trunk compartment, spare tire compartment, it reduced road noise big time, im planning on doing the floor also in the future, im just not fond on removing the carpet, but eventually i will.
Glad to know I'm not alone. Please post any photos of anything that you do and share any tips along the way. If you come across a video or any info of interior removal please post here. I'll do the same. I look forward to seeing what you folks come up with.
#11 ·
I took a peek under the carpet this afternoon. It looks well insulated to me. There is 1/2" insulation under the carpet that extends up high under the dash. I'm pretty impressed with what I saw. I plan to peek behind the door panel in the near future. I popped off the drive side door sill trim and kick panel and pulled back the carpet. You can see a solid piece of foam that supports the dead pedal but the insulation us under it too.
You'll probably find that there is little to no sound insulation in the doors of a Corolla. I found that my Avalon had very little in the doors from the factory. For my treatment, I used CLD, butyl rope, Tesa Tape and CCF to quiet the doors. It made a substantial difference. Probably more than you want to do, but I did it as part as a complete interior project (see signature).
#14 ·
The "Dynamat type stuff" is the CLD (Constrained Layer Dampener). That will help with resonance (vibration) of the metal panels. Use that directly on the outer and inner skins of your door.
The "ensulite (thin foam)" is probably a CCF (Closed Cell Foam). CCF is used to dampen high frequency sounds and reduce sound reflections. That is more of a strategic placement product. For example a large piece behind the speaker or a complete sheet behind the inner door card.
If you choose to use it, the butyl rope and the tesa tape are used to stop different surfaces from vibrating or rattling. The tape is great for stopping the little plastic fasteners from rattling. The rope is used for sticking things together, like the vapor barrier to the inner skin as an example. It doesn't sound like you're going to go that far, but at least you know what they're for... The CLD will still give you the biggest benefit.
#16 ·
I still find my Corolla is very noisy even it only come with 16", but mainly on poor sealed road. I think this is a very good topic to discuss (y)
Most journalists' reviews have mentioned about the high noise level of the Corollas with18" wheels on them. I think the 17" would fit the Corolla best. As you said, it would put extra weight on the Corolla to add these sound deafening material and also involved a lot of work. But I remember reading somewhere saying that there are only a few areas of the car needed to be installed with these material and it would make no difference of noise insulation improvement even if you put them all over the car.
#22 ·
I will.
Best way is to get Bridgestone Turanza Quiettrack tires. They are fantastic - long lasting, quiet, great all weather traction.
Thanks for the info. I appreciate the comments on tires helping with sound but I hope to keep this thread about insulation/dampening.
I intend to search TN about tires on the Gen 12. I hope there is a thread..... otherwise I might start one of those too. :)
#23 ·
@rybern:
Yes, quieter tires will help (depending on the before and after models, sometimes a lot), but you can still make a big difference with dampening only. Total ambient noise abatement is a cumulative effect thing. Each reduction in noise intrusion will make an incremental difference.
CLD and CCF will yield the most benefit for your cost and time. I do suggest that you choose a CLD that is better than Noico or similar. Quality makes a difference. I like Kno Knoise Kolossus, myself. Additionally, you don't have to treat everything all at once. You can do it over an extended time to fit your needs.
I've read that MLV/CCF is very effective too but it can be difficult to install. I've not tried it, though.
As far as placement, the largest improvement in my experience has come from the doors first, wheel wells second, firewall/floor pan/trunk third and finally roof (if rain noise irritates you). I've done all on a few different vehicles as part of sound system upgrades. You'll find that long drives are less tiring after you have completed the improvements.
#24 ·
I spent all day putting down “Kilmat 80 mil 36 sqft Car Sound Deadening Mat, Butyl Automotive Sound Deadener, Audio Noise Insulation and dampening” bought off Amazon.
Did all four doors and hatch area near spare. Also did some above the rear wheels in the hatch area. It did make a difference, but these stock avid tires are loud.
I think the material weighed around 17lbs.
It took a lot of effort but I’d do it again if I get another car.
#25 ·
I can sympathize on the time. I did it in stages though... probably about 40-50 hours all together (I put in more than just the CLD). I did outer door skins, inner door skins, door cards, trunk, trunk lid, wheel wells, floor, firewall, package shelf, roof, hood, quarter panels and many of the plastic trim panels. I had to use some thinner 80mil for some locations for fitment. I think I probably put in about 120# all together. Well worth the time and effort IMHO. I will treat any car I get, but I keep my cars for a long time. I had an estimate at a high end stereo shop for similar dampening and they wanted over $4,000 for less treatment than what I did.
I don't know which Avid tires you've got. I've got Avid Ascend GTs (225/50R18... originally 45s) and I think they're pretty quiet. I can barely hear them except for expansion joints.
#26 ·
You can go to home depot and buy a tar based flashing that has aluminum on one side or with out the aluminum backing. I am a bit buzzed up on Vodka right now and can not remember what it is called. It is almost identical to car based sound deadening material but less than 1/3 the price. Put it on the floor under carpet, around wheel wheels, trunk etc....Get a hard roller to get it to adhere well. DO the firewall as well. If it does not have hood matting do that as well.
Beyond that OEM tires on the base model or the lower end cars tend to be compromised and noisy! When you get your first set of new tires decide if you want performance or good ride and low noise as they seldom travel in the same design. Touring type designs tend to be lower in noise and performance tires, extreme use like police tires or truck tires designs tend to be noisy!
P.S. Getting M1 0W40, Redline Performance 0W40 or 5W40 or Redline Series 3000 5W30 will likely drop the noiise as well.
#28 ·
I just ordered 80 mil Kilmat and Vibro 228 from Ebay:
#29 ·
That'll probably work for you and for not a ton of $. I'm glad you didn't take earlier advice to get asphault based from the hardware store. Sure, it costs less, but I've read horror stories of smell and material melting/dripping after a few years from installation.
When all is done, report back. I'd like to hear your thoughts on the difference.
#32 ·
I pulled the door card off to take a peek. The video in post #30 makes this pretty quick and easy. Due to the lack of dampening material in the door and door card, I'm very encouraged that the materials I ordered from E-bay are going to make a substantial difference. Car is a 2021 Corolla XSE with the standard audio system.
One lonely piece of dampening material.
There is a little bit of insulation on the back of the door card but I see room for substantial improvement. The white on the upper part is plastic. The white on the lower part of the panel is a fluffy insulation.
Pioneer's smallest 6.5" magnet, LOL. FYI, it's a 4 ohm speaker.
#34 ·
I also purchased a decible meter off Ebay so I can see the actual difference. ;)
#35 ·
Check my post. It can give you an idea how to do it.
#36 ·
Wow, you went all out. Thanks for the info.
